tronçonneuse 07 s
Le Deal du moment : -28%
Brandt LVE127J – Lave-vaisselle encastrable 12 ...
279.99 €
 tronçonneuse 07 s
PAPY51
PAPY51
Masculin Nombre de messages : 179
tronçonneuse 07 s Empty
MessageSujet: tronçonneuse 07 s   tronçonneuse 07 s EmptyMar 22 Nov 2011, 21:26
je possede une tronçonneuse stihl 07S, je voudrais savoir les caracteristiques de cette machine
merci d'avance
papy51
jf SMOKE
jf SMOKE
MessageSujet: Re: tronçonneuse 07 s   tronçonneuse 07 s EmptyMar 22 Nov 2011, 21:39
si ça peu 'taider j' ai pris ça sur un site que notre amis guy (favrot) m'a conseillé ;" chain saw collector "
Home | Chain Saws | Chain Saw Chain | Bar Mount Patterns | Carburetors | Manufacturers | Trademarks | Collectors | Bulletins | Events | Stolen Saws | Chain Saw Age Reprints | Newsletter | Marketplace | Parts Sources | Cartoons | Links | Your Host
Model: 07
MANUFACTURED BY: STIHL ANDREAS MASCHINENFABRIK
STUTTGART, GERMANY
SERIES OR ASSEMBLY NUMBER: 1107
YEAR INTRODUCED: 1961
YEAR DISCONTINUED: 1965
ENGINE DISPLACEMENT: 75 ccm (4.58 cu. in.)
NUMBER OF CYLINDERS: 1
CYLINDER BORE: 50 mm (2.0 in.)
PISTON STROKE: 38 mm (1.52 in.)
CYLINDER TYPE: Aluminum with chrome plated bore
INTAKE METHOD: Piston ported
MANUFACTURER ADVERTISED H.P.: 4,5 hk @ 7,500 R.P.M. DIN
WEIGHT : 10 kg with 40 cm bar & chain
22 lbs. with 17 in. bar & chain
OPERATOR CONFIGURATION: One Man operation
HANDLEBAR SYSTEM: Rigid
CHAIN BRAKE: none
CLUTCH: Centrifugal
DRIVE TYPE: Direct
CONSTRUCTION: Die cast magnesium
MAGNETO TYPE: Bosch flywheel magneto
CARBURETOR: Tillotson HL121A, B, HL-147B, HL-155A series
MAJOR REPAIR KIT: RK-88HL
MINOR REPAIR KIT: DG-5HL
AIR FILTER SYSTEM: Nylon mesh element
STARTER TYPE: Automatic rewind (Fairbanks Morse type)
OIL PUMP: Automatic
OPERATING RPM: 7,000 to 7,500
IGNITION TIMING: 2.8 mm (0.112 in.) before TDC
BREAKER POINT SETTING: 0.4 mm (0.016 in.)
FLYWHEEL/COIL AIR GAP: Position is fixed
SPARK PLUG TYPE: Bosch W175T1
SPARK PLUG GAP: 0.51 mm (0.020 in.)
CRANKSHAFT MAIN BEARINGS: Ball
FUEL TANK CAPACITY: 1 litre (2.1 pints)
FUEL OIL RATIO: 20:1 after break in
RECOMMENDED FUEL OCTANE: Regular
MIX OIL SPECIFICATION: Castrol 2-stroke SAE 40
CHAIN PITCH: .404 in.
CHAIN TYPE: Oregon Chipper
BAR MOUNT PATTERN:
SHORTEST GUIDE BAR SUPPLIED: 43 cm (17 in.)
LONGEST GUIDE BAR SUPPLIED: 53 cm (21 in.)
COLOUR SCHEME: Grey with Red carburetor shroud and bar clamp
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
COMMENTS: replaced by 07S
Reproduction of this World Wide Web Site in whole or in part is prohibited without permission.
Copyright © 2000-2011 MIKE ACRES - All rights are reserved.
a bientot JF
PAPY51
PAPY51
MessageSujet: re   tronçonneuse 07 s EmptyMar 22 Nov 2011, 22:10
re bonsoir
oui je te remercis beaucoup on peut pas mieux
merci encore
papy51
favrot
favrot
Masculin Nombre de messages : 1242
MessageSujet: Re: tronçonneuse 07 s   tronçonneuse 07 s EmptySam 26 Nov 2011, 11:55
bonjour à tous, salut JF
Tu as bien appris ta le leçon !
Il faut savoir:
deux versions : 07 les premières et après 07S
Comme la 08 et la 08S .
Guy
http://collectionneur-tronconneuse.fr/
tronçonneuse 07 s
» tronçonneuse
» tronconneuse
» tronçonneuse ppk
» tronçonneuse ppk 80
» Tronçonneuse bis
